I’ve scoured these forums trying to get a double-tap on my LZW30-SN to trigger an automation in Home Assistant, but no matter what I do I can’t get HA to respond to the event.
I’m using HA 2021.4.6 with a Zooz USB stick and Z-Wave JS plugin. I have numerous Inovelli devices working flawlessly for non-scene based automations.
The switch in question is node ID 14 and the “Instant On” setting is DISABLED.
When I double-tap the “on” paddle, I see an event in both the Z-Wave JS debug console and log files confirming scene “2” and “KeyPressed2x”:
However, using HA dev tools, I do NOT see any “zwave_js_event” events:
I have configured the HA automation according to other posts I’ve seen here:
If I use the dev tools to manually trigger a “zwave_js_event” with those params then the automation DOES fire.
So, it seems like HA isn’t recognizing the Z-wave traffic generated by my double-tap as a “zwave_js_event” with those parameters, and that’s where I’m stuck. I have no idea what to troubleshoot next. Any suggestions?
