Apologies if this has been asked and answered… I’m expecting my first zed-wave devices (Red Dimmers and Switches in the upcoming batch, maybe early next week when the ship arrives?)
I’ll be using my existing Home Assistant setup, I run HASSOS in a VM on Unraid.
Need to get a USB stick. I don’t know which one. A bit of a price gap and I really don’t know what the described features actually give me - do I just go for the cheapest one, or are any of the noted features actually worth it?
I don’t do Zigbee, so that’s not really a selling feature for me. The Aeotec 7-series isn’t available yet and I’m not sure it’ll actually do anything for me since I’m fairly certain the Red series devices I’m getting aren’t 7-series yet?
The older Aeotecs have a battery and button but again not sure if that actually adds any value.
Do I just get the cheapest, or will any of these actually work better (better range, better stability, better features)?
I just bought the zwave.me one the other day and have no complaints. Think it’s the one I’ve seen Inovelli recommend in the past too. That said, I also just got a conbee 2 after deciding to move my zigbee devices to HomeAssistant also, so the HUSBZB-1 is tempting for that. Just a question of having separate or a shared zwave/zigbee controller if you want that.
Ha - that is a very good point and tbh, if there was stock I likely would have just gotten it without even asking. But, dimmers & switches are coming and it would be tragic to just wait for a stick…
Something to keep in mind is that upgrading your controller may not be trivial. A fair amount of information about your zwave network lives on the stick, and getting that information off of the stick to move to another isn’t guaranteed to be possible. Knowing that now, I might have waited for a 700-series stick and used a standalone zigbee stick for the few zigbee devices I have (that came with the house). As it stands, I think I’m looking at completely rebuilding my zwave network when I finally get a 700-series stick. I’m not looking forward to that.
I upgraded to this one from a zwave.me stick to add zigbee (and finally get off ST permanently) and it is perceptibly faster to me. I also rebuilt my entire network, so that might be part of it as well.
I spent a good amount of time playing around with various different Zwave sticks as well as Zigbee sticks. I had bad luck with the Cronbee II for Zigbee, I moved away from that one after only a couple days. I also tried a couple no name Zigbee sticks and quickly concluded you get what you pay for.
For Zwave I had a horrible time with both the ZST10 500 and ZST10 700 from Zooz. They made my whole network sluggish and nothing I did fixed that.
The only thing that continues to work almost perfectly for me is the GoControl HUSBZB-1. It’s super speedy and always just works no matter where I place it. I recommend this one to everyone I know as a starting point if nothing else.
It’s not perfect of course, but no product is in the end.
and now for the exciting conclusion - ordered the zwave.me stick because it was cheapest, then changed my mind, cancelled that order, and ordered the USBZB-1 instead.
The value of the battery is that if you need to pair a device and you’re having trouble because of range issues - you could pull the stick out of your server and bring it to the device and re-initiate pairing.
So whether that is important for you is situational - if your furthest device will still have a decent signal going back to your server then the battery is an unneeded feature.
IMO – the best (and cheapest) option is the UZB-7 (SLUSB001A). It’s from Silicon Labs, it’s 700 series, firmware updates are readily available and it’s only $20.
The HUSBZB-1 is/was a good device, but it’s going on something like 5+ years old at this point. There are better options available for both Zigbee and Z-Wave at this point.
In general, doing this is a bad idea. Controllers are meant to be static and not moved around. Doing so is likely to lead to issues that may not be fixable with a network heal.
I can’t really speak to that - all I know is Aoetec specifically endorses this in their documentation. In fact, their steps for pairing a new device seemingly require it;
Unplug the Z-Stick Gen5 from any USB connection, this will enable Network management mode.
Tap the button once on Z-Stick Gen5+. Its LED will blink blue slowly to indicate it is in pair mode.
Follow the instruction of the Z-Wave device that you want to pair. Typically the button press on the Z-Wave device is a single tap, but some have special button presses (ie. hold for 2 seconds and release, triple tap, double tap, etc).
Z-Stick Gen5+ LED will confirm if it paired something successfully by showing a solid blue LED for 2 seconds before returning to a slow blinking blue LED.
Repeat step 3 for any device you want to pair if you have multiple devices that you need to include.
When done, tap the button once on Z-Stick Gen5+ to bring it out of pair/include mode. The LED will de-activate.
Just a word of caution. I spent a good chunk of last weekend troubleshooting a zooz 700 USB stick and found it does not play nicely with raspberry pi 4. Basically the driver gets hung on boot and HA can’t use the device unless you manually unplug it and plug it back in, same issue if you update HA. No issues on raspberry pi 3b+. I suspect the issue is with the pi 4 only because they have had issues with other USB devices but just my best guess.
Thanks Stu! I looked for a solution like this on the pi 4 but sadly you can’t individually control USB ports on the pi 4, you can only toggle all of them which won’t work for my current setup because it’s USB boot. I do plan to switch to an Intel nuc so this might come in handy soon!!
I gave that a shot with the non-external powered Aukey USB hub I had on hand without any luck. For now I’m going attempt connecting the stick to a pi 3b+ and use the zwavejs ingeration on my pi 4 to communicate via websocket. I setup a small POC and was really happy with how well it worked. I have 2 more zwave sticks in route and intend to setup one per floor at my home. I want to try eliminating “hops” and have all my zwave devices direct connected to a stick.
