Getting ready to start installing smart switches and have settled on Red Series.
Most of the led lighting in my home is already on Lutron “dumb” dimmers with the typical single dimmer and one or two dumb switches connected. My home is only 4 years old so I assume I have neutral wires in place.
Questions I have:
I’m leaning towards not using any dumb switches and using dimmers on both ends rather than having one dumb non dimmable switch… Is there any issue with doing this or something special that needs to be taken into consideration?
I have a few areas where I have 3-4 switches that control a set of lights, As per above, can I use all smart switches in this type of configuration and if so, any special provisioning or consideration needed before I start pouring money into this?
