3-Way Question Inovelli
I bought a bunch of red series dimmers and some GE enbrighten companion switches. Electricians are here and am having a hard time understanding the documentation.
Questions:
  1. The Inovelli switch will control the load directly, correct? Without adding to the Z-Wave network?
  2. Will the companion switch also control the load without associating it with the Inovelli switch?
  3. Will the companion switch also dim?
  • Yes. Just need to setup the parameters locally from the switch. See support.inovelli.com for manual.
  • Yes, there is no associations with AUX Switches. Once you set the parameter 22 correctly, you will be able to use the AUX switch like a typicaly 3-way.
  • Yes it will.
Following up on @harjms comments.
You’ll have to program the Inovelli via the config button if it’s not connected to a hub. These three vids show how to configure neutral installation w/aux, neutral installation w/dumb and non-neutral w/aux:
Thank you. I got it to work.
FYI: This How-To instruction says tap config button 11 times for power type and 12 times for switch type. After watching the video tapping 12 and 13 times worked.
I like your product a lot so far. I’m transitioning from UPB since Simply Automated is quasi shut down. I’m really happy you came out with the scene controller. It’s a feature UPB has that I couldn’t find in Z-Wave until now.
