4 way associate with 3rd Generation Red Switches
Hey all,
So I just installed the new Gen3 Red Switches in a 4 way configuration (only off an on, not dimming at the moment). I’ve setup group associations between the switches for groups 2-4. On the switch attached to the load, the setting for Send Local Commands to Associated Devices and Forward Z-Wave Commands to Associated Devices are enabled. On the switches that aren’t attached to the load, only Send Local Commands to Associated Devices are turned on. This works fine as far as controlling the load from all the switches, and the switches all match states (all on when on, off when off). The issue I’m trying to solve is that the switches that don’t have a load attached, don’t send any updates to the controller (home assistant), when controlled by a remote switch. Is there an option to fix this?
Craig
