Is it possible to have a 4 way install with 2 Inovelli Red series dimmers and one GE Aux?
Thanks
Thanks
Welcome
The answer is yes maybe.
It would have to be wired similar to this:
Setup:
You associate the Red Dimmer 1 with Red dimmer 2 so they mirror each other.
If you have a sketch we could take a look.
I assume you don’t want 2 Aux switches(dimmers really) because you want the 2nd dimmer location to have the LEDs. If not consider 2 Aux.
My experience:
Usually the issue is in the box the 4-way switch is located. I am about to replace my dumb 4-way with a Red Dimmer. Luckly in the same box is my front entrance light switch. I am using the power and neutral from the front entrance light to power the Red Dimmer I’m adding.
John
