(Copied from my Facebook post, so apologies if you’ve already seen it.)
So I just got 6 Inovelli RGBW bulbs installed and paired in my home theater room fixtures. I have one Inovelli Red dimmer that controls the two 3-bulb fixtures.
I went to set up the associations and, to my horror, have discovered that there seems to be a 5 device limit for associations (or at least that’s what it looks like to me). I can set the dimmer to control the six bulbs, but the last one just ignores the commands (or, more likely, the association tool just ignores my attempt to add a sixth).
At first I thought it might be a defective bulb, so I excluded it and installed a different one. Then set up the association with the new one. Same result.
Is there any way to over come this? I tried setting up a Group and using that, but that doesn’t seem to work for Z-Wave associations (it had no effect).
I don’t think I can use Rule Manager, because I haven’t seen how you can set up a rule to respond to dimming from the dimmer. But if that’s possible, please advise and I’ll pursue that.
I’m thinking I may just pull one bulb out from one of the fixtures. That sucks.
