Binding Confusion
I have two Blue 2-in-1 switches and I cannot seem to get the binding configured correctly. Switch #1 has the load on in it and should be set to be a dimmer. Switch #2 is a virtual 3 way that I would like to be able to control switch #1 and keep the “dim level” in sync with. So here is what I did,
Created a group called “my lights” in which switch #1 endpoint #1 is a member. Bound endpoint 2 on switch #1 to the group, and bound endpoint #2 on switch #2 to the group.
Everything is working correctly EXCEPT the dimmer LED bar doesn’t seem to track the group.
How do I fix this?
EDIT: Switch #2 has nothing on the load, and thus I just want to disable the relay/dimmer in it.
Add endpoint 1 of switch 2 to the group as well. For it to track state, you need all switches (ep1) in the group and all switches (ep2) bound to the group.
