I just added three more Inovelli switches to my Home Assistant config: two red on/offs and a black on/off.
The red switches came up fine as proper Inovelli Switches in Home Assistant. The black one did not, sadly. It showed up as:
“Inovelli Unknown: type=0004, id=0001”
I have the local version of openzwave and have modified the .xml file to list all the Inovelli stuff. I tried removing and re-adding the switch, and tried rebooting HA, but got the same thing.
That’s because the guide you followed is missing information. It does not have the black series switch listed (see that there is no “type=0004, id=0001” in what follows):
Thanks, I figured it would be something like that. I did those updates, zwave removed the device, rebooted Home Assistant, and added it back in… and still got Inovelli Unknown. Is there anything else I have to clean out because it was previously paired to the system as unknown?
