I have a ceiling fan with lights. The switch at the wall turns the light and fan on and off together. I was told it is switch loop wiring. There is a white wire, a black wire and a ground wire at the switch in the wall. My ceiling fan has pull strings for the light and fan. Can i use the blue dimmer switch and the blue fan canopy module? Is there a diagram for the wiring for switch loop wiring or can someone tell me how it should be done if it is even possible? Also, if it is possible, can i use smart bulbs also. (The switch on the right is just a closet and will probably stay dumb)
Thanks for any help
