Blue 2-1 Relay Click in HomeAssistant ZHA
Looking at the firmware parameters for the 2-1 switch, I can see there is a setting to disable the relay click, but I cannot find this in ZHA. How do I turn the click off in HomeAssistant using ZHA?
I’m running ZHA and I have a setting under the Configuration section of the switch called “Disable relay click in on off mode”
Seems to work just fine.
Thank you, I was looking int the Zigbee configuration pop-up and didn’t see that in the device itself.
