I had an issue when updating Z2M in Home Assistant that resulted in the addon crashing when it started. The issue persisted even after rolling back the version. I ended up having to generate a new panID. So now I need to pair all my Zigbee devices again. I’m starting with my routers. I couldn’t put any of my Blue switches into pairing mode. So I figured I needed to reset them to do that. I was reset one switch and it paired just fine with the coordinator. I reset a second switch, but it won’t pair. I’ve tried several times. I even tried pulling out the air gap.
Has anyone seen this before?
