I just spent the day wiring in 4 Blue fan canopy and dimmer combos. All went well with three of them but the 4th has a strange issue I cannot figure out. All were wired the same and the dimmers setup using dual Zigbee bindings with the paddles as on off dimmers for the fan lights and the favorites button used multi tap for the fan. The malfunctioning switch paddle works fine. The multi tap turns on the fan and light to the corresponding level. 1 tap 33 for for both light and fan. Two tap 66 for light and fan. Ect. If I control from the Hubitat hub, the fan does not turn on the light. Only from the favorites button. I tried deleting and readding the Zigbee bindings but that does not work. Does anyone have any ideas why 3 work perfect and 1 does not? Thanks for any help..
