I have four recessed lights controlled by a single 3-way switch setup. I.e., I flip one of the two switches, and all four lights toggle. My switches have no neutrals in the box. I tried installing an Inovelli blue 2-1 switch + aux switch according to the wiring diagram for no-neutral, but I got flickering. I see that this means I need a bypass, however, I can’t find any information on installing a bypass with multiple fixtures.
- Do I need to go up into my attic and wire the bypass across all the fixtures? Or can I just install the bypass in a single fixture, just accessing the box from my living space?
- If the latter, then I want to confirm how to do that. The lights I’m using are Philips Hue can light retrofits. There’s a connector with an E26 base at one end to screw into the can, with two wires running to a piece that plugs into the light. To install the bypass, do I just (1) cut those two wires, (2) splice each of them back together with 3-wire wagos, and (3) insert each of the bypass wires into the remaining slots on the wagos?
(If anyone’s wondering why I want smart switches and smart lights, it’s so that I can change the color temperature on the lights, but maintain local control over brightness. Using Home Assistant adaptive lighting.)
