My new home currently has these LED lights installed throughout most of the house.
https://www.elliottelectric.com/P/Item/ETL/RL560WH6827/
https://www.homedepot.com/p/Halo-5-in-and-6-in-2700K-Matte-White-Recessed-Retrofit-Baffle-Trim-LED-Module-80-CRI-RL560WH6827/204280491#product-overview
Can I used the Red Series dimmers with these? I see the wattage is pretty low on these lights (8 watts per bulb)
They are currently on standard non smart Lutron dimmer switches and seem to dim just fine but want to make sure I’m not missing anything before buying 20 of these Red Series dimmers.
It looks like these bulbs work with leading edge and trailing edge phase control dimmers.
According to the Compatible Bulb List, the dimmers are MOSFET (Leading edge) based. Coupled with several other Eaton bulbs on the list, I suspect these will be compatible.
That being said you can always order a single dimmer to test before committing to buy a 10 pack.
