I setup a group in HE that has 3 RGBW bulbs and the “(Light LED)”
I have local switch protection turned on for the light, and then a lighting rule that when the top button it pressed, it toggles a few bulbs (SunroomGP) between on and off. the problem is that the “Light LED” will never go off, meaning that once the light is turned on, HE never knows that the group is truly off, so when you push the button
I tried installing the Child when Off , but that does not seem to help either. Ideas?
