I am using the Red Series Dimmer Switch (Z-Wave). I am confused about the parameters that can be set at the switch (not via separate software).
For example, the manual says (at the bottom of Page 10):
Disable Internal Relay, config button, press 8x times
But on Page 9 it says “LED Indicator color, config button, press 8x times”
By experimentation I found that Page 10 is correct and Page 9 isn’t but I need to change some other parameters, such as Power On State, which isn’t listed on Page 10.
I am not asking how to change these in software. I want to be able to change them at the switch. Is there a definitive and correct list of “how many times to press the config button” to “function” mapping?
