There are a number of parameter settings that I’d like all switches to use - is it possible to set these defaults in the driver? Or do you always have to modify the settings on each switch?
You have to set them for each switch. Drivers generally don’t (AFAIK) proactively transmit settings to the switch unless you tell them to.
