Dimming wiring - only 3 wires in the box
Hi I am trying to replace a Lutron Diva CL switch with a blue series Inovelli dimmer switch. It controls a handful of ceiling lights that dim with the Diva switch, and there is a dumb switch elsewhere in the room that turns the same lights on and off.
I am confused on how to wire it up, because all of the 3-way diagrams show 4 wires, and there are only 3 wires coming out of my box + ground. I assume that means I have no neutral wire and need to replace the dumb switch with an aux switch, but just wanted to confirm.
This is a “dead-end” 3-way. You will want to install the Inovelli dimmer at the location of the other 3-way switch for that lighting circuit.
EDIT:
The switch in the photo is the box on the right in this diagram. You will need to move the dumb switch to the box in the photo.
