I’ve successfully been able to create notifications using home assistant using one parameter at a time. It works well but I don’t know how to set the switch back to its default behavior when the notification needs to stop.
What config parameter or value?
alias: TEST Change LED
sequence:
- service: zwave_js.set_config_parameter
data:
value: 3
parameter: '16'
bitmask: 2130706432
target:
entity_id:
- light.globe
data:
parameter: '16'
value: 0
bitmask: 65280
target:
entity_id: light.globe
data:
parameter: '16'
value: 255
bitmask: 16711680
target:
data:
parameter: '16'
value: 10
bitmask: 65280
target:
mode: single
Please and thank you!!
