I’ve got 9 of these throughout the house and only having one that seems to be using the LED Timeout when the device is on, even though they’re all setup in Hubitat the same way with a 2 second Timeout only 1 seems to be actually doing it. I’ve decided that I don’t want the timeout is there a way to disable it so that when it’s on the LED stays on, and doesn’t timeout? they are all on firmware 1.48 the hub is a C5 (if that matters, on the latest firmware). Any suggestions are welcome, i’ve tried selecting No selection, and that doesn’t seem to change the timeout.
Thank you
