When entering in configuration mode on the LZW31-SN, is there anyway to read the currently configuration value of a given parameter?
When I press the config button the correct # of times, it will flash yellow the parameter number, but not flash purple the currently set configuration value.
I just spent 1.5h trying to figure out why my switch wasn’t working correctly, when the only problem was the configuration value was different than what was specified as the factory-default value. Being able to read the value at the switch would have saved me plenty of headaches.
Thanks,
Eric
