I have a simple Hubitat rule machine rule that turns on one VZW31 when another one turns on. This works great when controlled through Hubitat on/off. When I go to the the switch itself it does not work. What parameter do I have wrong?
I went back and turned on the logs for the Inovelli switches. When I turn on through Hubitat it logs as turning on. When I go to the switch and hit the paddle, the Hubitat does not log the state change. Why doesn’t the switch report the state change to Hubitat at the switch?
I updated the Hubitat device driver from 2023 to the 2024 version. Initialized and configured. All is working perfectly. Hub commands and local commands both log properly and the rule machine rule works both ways. Thanks for the help.
