I’m going to glance over it… Some of the functions I used are hubitat specific… Also hubitat seems to have more strict standards (which I like)… I just don’t have a smartthings hub to test with at the moment
I gave my old smartthings hub to a friend that is just starting out in smart home… Also gave him my lightify bulbs that I replaced with inovelli
aha! I didn’t realize this was the same one you mentioned on hubitat forum. It def should have gotten a Eric M touch up before showing up on Smartthings side of device handlers.
On a side note, i’ve been reading your posts and work on hubitat and hope to some day soon make the move. Been getting my ducks in a row because I need something that just works
Yes, that is accurate…and I mentioned issues with relay disabled. However the provided documentation with their dimmers says the relay “may have to be disabled” with smart bulbs. Disabling the relay sadly causes the dimmer to not work as intended. As observed by many and described in detail here: Red Series Dimmer (LZW31-SN) observations and comments
Either way the provided handler isn’t currently SmartThings friendly in any situation I’ve tested other than Red v2 On/Off switches
I am happy to report that the updated DH script seems to have fixed my issue. I can now change the colors on the bulb without the bulbs turning off and becoming unresponsive and the bulbs consistently get included with the proper name (Inovelli multicolor bulb) rather than a generic dimmer switch.
With the new DH, the bulbs constantly show as unavailable in ST. They still respond to zwave association from the physical press of the switch even while showing unavailable, but they do not respond to zwave commands sent to the switch. I switched back to the old DH and issue went away.
