Inovelli as Aux Switches
Can the On / Off Black Series switch be used as an Aux switch? If so, can the On / Off Black Series as an Aux switch activate scenes based on the primary On / Off Red Series?
Is the same true for the dimmers, mixing and matching?
I thought I saw a wiring diagram for Aux switches too?
I think this would be possible. You would associate the switches together using your hub and sending configuration parameters to the switches so that they directly control each other.
For scenes, I don’t think it would be possible. The switch itself would have to support sending scene commands and I don’t know if the Black can do that.
