I am running Home Assistant (21.6.6) on a Raspberry Pi.
I installed ZWAVE JS in SUPERVISOR.
I installed ZWAVE JS in CONFIGURATION.
Yesterday, I was able to add a node (3) a Inovelli LZW31-SN Red-Series Dimmer.
For some reasons, it stop responding this morning. I tried to add the node again, without success. I even factory reset the unit (holding the config button for 20 seconds). I cannot add the node.
ZWAVE JS (config) indicate that I have 2 devices my Z-Stick Gen5 (node status : Alive; node ready; YES) and Node 3 (node status : DEAD and node ready : NO.
Any suggestion how to remove this node and reinstalled my switch
I have 5 more Inovelli switches to migrate to Home Assistant
May get more help in the HA forums. I use HA but I run ZwaveJS2MQTT. I’d think if you factory rest the unit, you should be able to add it again. When you factory reset, are you waiting for the light to turn red? I’ve found its not always 20 seconds on the dot
Is this device the closest device to your z-wave stick? How far is the device from the stick?
In general, make sure you start with the device(s) nearest to the stick and work your way out. You can also get more real-time help in the Z-Wave channel on the Home Assistant Discord chat.
