Inverting the LZW31-SN LED animation
Parameter 7 on this switch inverts the paddles. I have a few locations where the switch being inverted works better, but I noticed after changing the parameter, it only inverts the paddles, and not the LED animation.
So if I’m dimming up or down, the LED animation is still going the original direction. eg, if I hold up, the animation starts at the top and works down, and vice versa.
Is this intended? Can it be inverted as well?
