Installed some Red Dimmers yesterday and noticed the LED bar on one of them is not lit.
It is a 3 way switch with another Red Dimmer on the other end. The working dimmer is the line switch and the non longer working switch is the load side.
I’ve tried resetting the breaker with no change. Home Assistant Zwavejs to mqtt is showing the device as “alive” however the firmware field is blank now.
