Blue 2-1 & Red Series
When I have my switch off and no LED notification setup the LED has a tint of blue
How come I can’t get my notification brightness that low?
My main issue is at night when we are sleeping, tthe LED is too bright for the bedrooms even on the lowest setting for notifications.
What hub are you using? This should be 100% possible as there are 4 variables when setting up a notification:
Type of Effect
Color
Level (which is what you want)
Duration
bradsjm
January 24, 2023, 1:09am
#3
@jrvisconti I just looked at I see the brightness for the tint of blue in the Inovelli driver and it is level 3, but the lowest setting I have on my notification app is 10 so I’m thinking that may be why. I will make an update to allow for custom values to be sent to the driver.
@Eric_Inovelli @bradsjm I never checked my Blue 2-1 switches, only my Red Series.
I can go from 0-100 using the Led Effect All under the hubitat device page on the Blue 2-1
I can’t seem to figure out how to do it on the Red Series.
When I use the Inovelli Switch Tool box to generate a configuration value the lowest value still seems a bit bright
jrvisconti:
Red Series
Red series is only on a 10’s scale. Blues are on a 254 scale.
Does that mean it’s a firmware limitation, something overlooked, or a firmware bug?
Firmware limitation/memory limitation. Red 500 series only had so much firmware space.
