Hey, new to Inovelli and Zwave, but a long time automation fanatic using Insteon and isy994 gear. I am in a new place and picked up one Inovelli red series g2 dimmer to try out. I have been using Philips LED BR30 457044 (not Hue) for a while now because they dim so well and go super low compared to other LED bulbs. After installing the switch with a neutral and a traveler I got strobing on the lights way slower than a flicker and happened all the way up to 100%. I pulled one and added an incandescent to test it and both it and the other LED dimmed fine.
I have been reading that some bulbs are incompatible, but i am also reading that some folks are using Philips LED bulbs. So I am a bit confused.
Is this a wiring issue or do I need new bulbs. If I need new bulbs, what is comparable to the Philips bulbs?
