So I received the 6 dimmers that I pre-ordered end of last week and started installing them over the weekend. I’ve got 5 of the 6 in so far and so far have been pretty happy. There’s ALOT you can do with these and I feel like I haven’t even scratched the surface yet in terms of scenes, notifications, integration, etc…
Installation wasn’t very hard at all. I’m a novice when it comes to AC wiring and really only ran into two minor hiccups when putting these in. I’m running these on a Smartthings hub and 4 of the 6 dimmers are on 3 way circuits. I’ve got a neutral wire in every location that a smart dimmer has gone into as well. Here’s my experience so far:
First dimmer installed in our bedroom was a normal dimmer controlling 4 led high hats. These are 13w sunco fully dimmable LED retrofits and I immediately noticed that all 4 did not fully shut off even after adjusting min/max settings, etc… I ended up having to put a bypass resistor behind the switch to take care of this. Not sure why as my living room has the exact same retrofits on 2 different circuits (split the living room lights into 2 groups of 2) and I do not have any problems with flickering/not shutting off completely on either dimmer).
When I first installed the dimmers in 3 way locations, everything seemed to be working until I realized I could only control the dumb switch if the smart dimmer had already been “on.” I assumed that I had simply wired something wrong but after pulling out the dimmers while I was troubleshooting with an electrician friend, I realized that I had simply not configured these in smartthings to be 3 ways.
Now that I’ve got all dimmers installed and working, I spent a lot of time last night messing around with scenes and notifications. It certainly isn’t what I would consider straightforward to get everything configured the way you want but you are definitely able to do a lot. I’ve setup a few scenes already and will be getting our logitech harmony hub hooked back up today or tomorrow. From what I’m reading, we should be able to use that to control scenes (ie movie) automatically when we press a button on the remote. Notifications are pretty cool too. I didn’t originally appreciate that you can set notifications to each dimmer individually which is nice. Currently I’ve got a notification for when our garage door opens and also another one that indicates when our opener has been turned off for the night (we’ve got a smartplug to the opener that’s set to shut off every night before bed).
Configuring the multiple button presses to activate scenes is also pretty great and it’s nice to be able to do this without having to rely on an app.
I have a feeling I’ll be going down a rabbit hole with integrating everything and getting it to work just the way we want but so far I’m pretty happy with these switches!
One thing i think would be useful (not sure if this is possible) would be to allow for multiple notifications on a switch. In other words, let’s say I’ve got notifications setup to indicate if the garage door is open and also whether the back door is locked-it would be nice to be able to have a single switch cycle through multiple notifications if they are present.
I’m sure I’ll run into other things as I spend more time but just wanted to share my thoughts for now! As frustrating as it was to wait what has essentially been a year and a half to get smart switches (I first started looking at Inovelli in July of 2018), I’m not happy that I decided to stick with them and not move to a different platform.
