Where can I find this setting?
Mine are slow and I cannot find this setting in the devices settings screen in Hubitat.
Thanks.
Yes.
Thanks for that.
I’m not using a dimmer though.
I don’t have any setting for delays or speed.
I’ll have to figure something else out.
What do you think about this setting?
@TheMigDig - I’ve always left this as default. Are you talking about the speed from the time the button is pressed to when the light actually comes on? There’s always going to be a delay (mainly due to scenes), but I know Inovelli is considering a firmware change that would increase the response possibly the Black Series switches (no scenes available).
Yes, that is the delay.
I have it set up in Hubitat.
I have a RULE MACHINE rule for a button device.
Push up and it turns relay1 on a zwave relay.
Push down and it turns same relay1 off on a zwave relay.
It ranges from 3-7 seconds.
Hoping it can be improved, otherwise family acceptance is unlikely.
These are dream devices other than that.
3-7 seconds I’m Hubitat?! I only see that delay with color changing of the bulbs. Everything Else pretty quick.
Yeah, that’s what I cannot explain. Gonna try logger to see what step is causing delay.
Have you tried performing Z Wave repair?
Hey guys, I moved this to a new topic – feel free to edit the post title. I got confused because the OP had an issue with a Dimmer, but @TheMigDig seems to have an issue with the On/Off switch.
@TheMigDig – keep us posted on the logs. I’ve definitely never seen this on Hubitat either.
Yes, multiple times and also whenever I add a device.
My setup in Hubitat:
Innovelli driver switch (ROOM SWITCH) with rule machine button device rule that turns on/off virtual switch ROOM LIGHT which triggers another rule machine rule (ROOM LIGHT RULE) that turns on1/off1 a dual relay (ROOM RELAY).
Two examples I just captured below:
This took 2.51s according to my phone’s timer.
dev:5452020-06-12 11:16:07.300 am debugParsed [email protected] to [['descriptionText': ROOM RELAY: [email protected]]]
app:2722020-06-12 11:16:06.036 am infoAction: END-IF
app:2722020-06-12 11:16:06.022 am infoAction: off1() on ROOM RELAY (skipped)
app:2722020-06-12 11:16:06.000 am infoAction: ELSE (skipping)
app:2722020-06-12 11:16:05.922 am infoAction: on1() on ROOM RELAY
app:2722020-06-12 11:16:05.900 am infoAction: IF (ROOM LIGHT(on) is on(T) [TRUE]) THEN
app:2722020-06-12 11:16:05.742 am info ROOM LIGHT RULE Triggered
app:2722020-06-12 11:16:05.713 am info ROOM LIGHT RULE: ROOM LIGHT switch on
dev:2602020-06-12 11:16:05.368 am info ROOM LIGHT was turned on
app:2742020-06-12 11:16:05.310 am infoAction: On: ROOM LIGHT
app:2742020-06-12 11:16:05.184 am info ROOM SWITCH RULE: ROOM SWITCH pushed 1
dev:2582020-06-12 11:16:04.896 am info ROOM SWITCH: Switch Binary report received with value of on
dev:2582020-06-12 11:16:04.891 am debug ROOM SWITCH: SwitchBinaryReport(value:255)
dev:2582020-06-12 11:16:04.755 am info ROOM SWITCH: Button 1 was pushed
dev:2582020-06-12 11:16:04.748 am debug ROOM SWITCH: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:70)
This took 3.89s:
dev:5452020-06-12 11:39:22.413 am debugParsed [email protected]e to [['descriptionText' ROOM RELAY: [email protected]e]]
app:2722020-06-12 11:39:21.216 am infoAction: END-IF
app:2722020-06-12 11:39:21.192 am infoAction: off1() on ROOM RELAY
app:2722020-06-12 11:39:21.185 am infoAction: ELSE (do actions)
app:2722020-06-12 11:39:21.182 am infoAction: on1() on ROOM RELAY (skipped)
app:2722020-06-12 11:39:21.175 am infoAction: IF (ROOM LIGHT(off) is on(F) [FALSE]) THEN (skipping)
app:2722020-06-12 11:39:21.122 am info ROOM LIGHT RULE Triggered
app:2722020-06-12 11:39:21.111 am info ROOM LIGHT RULE: ROOM LIGHT switch off
dev:2602020-06-12 11:39:20.968 am info ROOM LIGHT was turned off
app:2742020-06-12 11:39:20.957 am info Action: Off: ROOM LIGHT
app:2742020-06-12 11:39:20.910 am info ROOM SWITCH RULE: ROOM SWITCH held 1
dev:2582020-06-12 11:39:20.907 am info ROOM SWITCH: Switch Binary report received with value of off
dev:2582020-06-12 11:39:20.903 am debug ROOM SWITCH: SwitchBinaryReport(value:0)
dev:2582020-06-12 11:39:20.752 am info ROOM SWITCH: Button 1 was held
dev:2582020-06-12 11:39:20.749 am debug ROOM SWITCH: CentralSceneNotification(keyAttributes:0, sceneNumber:1, sequenceNumber:73)
Might be easier to trouble shoot this with screen shots from Rule Manager of your Rules, but my thoughts are is this is a Z-wave issue and a slow response to Z-wave commands in the mesh…Could be due to complex rules.
Some on Hubitat have slowness like this that a hub reboot cures…
