Does the LZW31 (black series dimmer) support being wired as a double pole so that it can control the loads (10 x 11w smart bulbs) on two separate circuits?
Thanks,
DFL
The short answer is no, but since you are using smart bulbs, you shouldn’t be directly controlling the smart bulbs anyway. They should be constantly powered. I would use a Red series switch and then control the bulbs via either a scene or direct association.
