Switch: Inovelli Dimmer LZW31
Install: Non-neutral
Load: Connected to two 7.5w LED Bulbs
Hub: ST V3 hub
Strange issue. When I turn the bulb on from the ST app, functions just fine EXCEPT when I turn it off, it blinks once before it shuts off. Very quick blink then off.
If I toggle the switch manually, the lights will flicker a little bit, and I can no longer get the switch to function at all and have to use the air gap switch to reset it.
First thought was that I should install a bypass, but isn’t it odd that the light only exhibits the odd functionality when the switch is toggled vs. remotely turned on?
