Wondering if the dimmer will work with my Elco Lighting EL1499ICA low voltage recessed housing. Will it be dangerous to try? Or will it pose any issues with long term reliability of the switch or lights.
Specs say it has a magnetic transformer and warn to “use only dimmers specifically designed for use with magnetic transformers.”
Product page: https://elcolighting.com/products/4-low-voltage-airtight-ic-housing
Spec Sheet: https://elcolighting.com/printpdf/products/4-low-voltage-airtight-ic-housing
Dimmer Compatibility List: https://elcolighting.com/sites/default/files/Low%20Voltage%20System_19.pdf
