LZW31-SN Firmware update 1.47 freezes
I am trying to update the firmware on my Red Ser V2 Dimmer. I am using the Firmware updater in Hubitat. It the firmware update is very slow and in the logs begins o repeat itself. It keeps sending the same packet over and over. It stops sending are found 15% and there is a red bar on the led bar on my dimmer switch.
The switch is in a 3way config with a GE add on switch.
Use the binary updater
