New to the forum and new to the LZW31-SN. Does documentation exist for the “toggles” in the driver, especially “Default Level (Local)” and “Default Level (Z-Wave)”. I’m not sure what the intended use case is for these.
Turning those on will create child devices that allow you to adjust those parameters from an external source like Rule Machine.
For example, you might write a rule that sets the default level to 25% between certain night hours, and 100% other times.
Ahhh… Thank you very much!!
