LZW31-SN (Red Dimmer) x2 - 3 way with separate line/ load
This can be done if using associations from what has been told. I don’t have two in-line for a configuration to check. I believe people got it going with Group 3 N 4.
I can confirm it works via association. Set parameter 12 to 11 on one of the dimmers otherwise they will fight over status. The non-load dimmer must have a neutral.
@skarden may be confusing a different configuration. If you associate a dimmer and an illium bulb (and turn on Smart Bulb mode) the LED bar is fixed at 100% unless you don’t connect the bulb to the load side of the dimmer.
