I’ve upgraded all my Red Dimmer v2 to T0 1.61 & T1 1.45 all my switch (about 18, it took days…), before I realized when in SmartBulb mode, “scene control” are not working…
It like the opt 51 (Disable On/Off Delay) is forced to Yes. I only have the up down, long press up, long press down and the small button (which allow a single click only). Is there any way to reenable that, or it a limitation of the firmware now ?
Several people, including myself, ran into issues after upgrading. Toggle param 50 (multi tap delay) to 1 and then to 7. I think the param gets sets to an invalid value when upgrading. If that doesn’t work toggle param 51 (multi tap delay on/off) to 0 and then back to 1.
Thanks, that worked ! I think maybe what I also did is installed inovelli latest driver and click configure. I remember in the other driver to have a dropdown to select the delay, but I don’t see it in this one… Maybe it a problem with the driver and not the firmware…
