LZW36 disable fan speed control
I’m considering connecting a LZW36 fan/light switch to my bathroom ceiling fan/light combo. I was wondering if there is a way to disable the fan controls so that it’s either on (high) or off? I don’t want low or medium fan speeds.
You can turn on local protection on the fan button and then set this up through your hub using the scene control and an automation. Something along the lines of if speed == high then turn off else set speed high.
