Does anyone have a simple setup guide for how to set up the device in Hubitat? I know how to pair it, and I have the driver, but I’m wondering about how to set all of the buttons, etc in the product on Hubitat.
I don’t have the device yet (it’s in the mail), I’m just trying to prepare…
Install the Hubitat Button Controllers app. Find the press/hold button mappings post in this forum. Program each button/combo for your desired functions.
You can also use Rule Manager in place of Button Controllers for more complex automations, using the same button presses/holds from the mapping post…
Only taps for on/off and the dimmer rockers are configured by default in a new device…as regular switches, a dimmer, and a fan speed controller. All of the 2/3/4/5 taps and holds “scene” stuff is configured as buttons afterwards:
When you configure an LED notification in the driver’s settings, it will automagically create a child switch device to turn it on/off for you as shown above…
I do not know if new orders are shipping with the latest “beta” firmware. If not, you may want to find the special Hubitat Z-Wave Firmware updater posted in these forums and have it on standby. The original shipping LZW36 firmware had an annoying canopy module disconnect issue, and should be upgraded right away if it is on your switch…
I looked in my logs and I seem to be getting this error when it’s “padding hex bytes”: java.lang.NullPointerException: Cannot invoke method and() on null object on line 461 (firmwareStore)
I’m using the 1.33 gbl file - assuming it’s better to update one version at a time?
