I installed the LZW36 FAN/LIGHT switch. The fan button works great. And the light button works great to turn on. But when I turn it off, the light bulbs stay on at a very dim setting, like 5 percent. I can see a glow in the bulbs. My hub shows the light is off. The only way to get the bulbs to turn off is to turn it back on and dim it all the way down. Any suggestions?
LED Bulbs? If so, you may need to install a Aeotec Bypass between the light and neutral wire. Some bulbs are more picky than others. Swapping bulbs may solve the issue, but I know some fans do not have that option. If that’s the case, then the bypass should help solve that issue.
