LZW60 not turning on light bulb after motion
So I would like to have the LZW60 turn on a light using a z-wave association.
I was able to set “Send Basic Set on Motion Send a Basic Set report to devices in association group 2” to Yes after a triple tapping the button to wake up the sensor.
parameter14value : 1
From best I can tell this should turn on the LZW42 with device network id ‘05’. The HE logs register the motion and the small LED glows red but the bulb remains off. Since HE sees the motion I could add a rule to turn on the light, but I would rather not create that dependency if it can be avoided.
any luck with this
