Hi all, just getting my Inovelli switches and dimmers going in a new-build home. The dimmers are all reporting energy just fine, but no energy/power stats from any of the switches (about 8 of them). Any obvious newbie errors that I might be overlooking? I did read about the neutral required and haven’t torn apart the electrician’s work yet as I thought I’d check to see if there was a special child device handler that’s different from the dimmers, or something like that first.
On the switches, have you checked the following parameters down under the preferences section? If you don’t see them labeled like this, you may want to try installing the Inovelli Hubitat drivers. If you can use the switches normally you are set up correctly as far as a neutral goes.
That is correct. Make sure you’re using the Inovelli driver you loaded under Drivers. You’ll select the Inovelli driver which is all the way at the bottom of the Hubitat list.
Just a thought, after swapping to the new driver, did you hit “Save Preferences” down below? And have you tried hitting the Configure and Refresh options to see what you get back in the logs?
It looks like I only see power logs with Informational logging enabled, and by default that will turn off after 30 minutes, but you should also have that information up in the current states as well like so -
Device and Manuf ID’s are not 0000, so good there. I replaced the device handler code that was loaded via hubitat package manager with the code on the github repo, and with that the ‘power’ appeared, but hasn’t moved, and no energy reported over 4 or 5 hours. I’m not sure if I’m making progress or not!
Oh and yes I did the save prefs/config/refresh commands with no results.
@Eric_Inovelli this is the first i have heard of a SWITCH not reporting power/energy, but add this to the list of people potentially experiencing failures to report on this.
I’ve been playing detective and just read on another thread that the devicetype: 4 means this would be a black series and not a red, which wasn’t what we spec’d, but maybe what the electrician bought and didn’t tell us. That would explain a lot if this is correct…
If you shoot me your electricians name or whomever placed the order (via PM), I can look officially. I meant to ask this yesterday as I tried pulling your email in our order system and it didn’t come up. I guess that would explain why if someone else ordered it lol!
