Modifying LZW45 T connectors and extension cables
With the new LZW45 led strips, there has been some discussion of a T connector that would serve as more of a true splitter, so for example, chase animations would proceed down both legs simultaneously instead of serially.
I was very interested in this for my use case as my controller will be in the middle of my strips rather than at the end. So, I modified one of my T connectors to enable this, and thought I would share.
Here’s the end result:
And here’s the modification. Note that if you do this, you do NOT want to use an end cap on either leg. Rather, you’ll just set parameter 1 to manually tell the controller the number of pixels on the longest leg.
To get the back off of the T connector, just find a tiny screwdriver and pry gently along the longest edge. It should pop right off.
I also took the heat shrink tubing off of one of the extension cables, as I wanted to make a shorter one. With a soldering iron, it’s pretty easy to shorten these and make the exact length you need:
That’s pretty slick, not gonna lie :smirk: Thanks for this awesome contribution!
Id like inovelli to sell just the connectors that are on the end of the extension cables. I will be shortening mine also, so I will have a lot of extra cable I could re-use if I had connectors.
