I love what Inovelli has done and want to share this idea with them.
Problem: The modern day light switch and wall plate is restrictive in nature and having to design a product that conforms to this is limiting.
Solution: You remove all the switches in your gang box and replace them with a simple module that has 2-5 channels that support dimming, provide 5VDC out, and a CAN bus. The wall plate contains the host controller, radio, and host on the CAN bus. It can talk to the module to control and get feedback of the dimmer and switch states. Now here is the bread and butter. The wall plate has snap in modules for paddles, buttons, epaper displays, etc. The wall plate communicates with these snap in modules via a can bus also. And the best part, the wall plate can be as big as you need it to be.
