So not sure if this topic has been broached yet but I would like to control both my interior entryway LED fixture (combined 12W) and outdoor fixture using the same Red Dimmer.
I just wired the entryway light using the dimmer while the outside light is using a dummy switch, both are in the same double gang box. The outside light is LED as well, under 10W I believe. I used the Aeotec bypass on the interior entryway fixture already. My questions are:
- Is this as simple as connecting the load for the exterior light to the second load hole on the switch?
- Would I need to add another bypass to the exterior fixture?
- Would the traveler connections on either switch be of any use?
This idea just popped into my head right after I finished the install so feel free to crush my dreams!
Thanks in advance!
