Pairing LZW30 problem with HA
hi all,
I am just getting started with the concept of home automation, so my question may be trivial to you. I would appreciate any help you can provide as I am currently struggling with it for a while.
I am in the process of changing most, if not all, switches at my house with Inovelli Z-wave Dimmer Switch (Black). I am using Armbian with HA 0.114.2. These Black dimmer switch were not natively supported (showed up as Inovelli Unknown, type-0003, id=0001), so I had to incorporate lzw31.xml that I found in this forum into my HA. The 1st of many paired just fine and I can control and change the setting of this dimmer switch in HA.
However, when I tried to pair the 2nd dimmer switch (after healing the network), it didn’t show up in HA. I think pairing went well because the LED bar turned green. However, under HD->configuration->Integrations->z-wave, the supposedly newly-paired dimmer switch does not show up: the number of paired devices remain unchanged.
Here is the log from HA. I understand this is not a HA forum but I wasn’t getting much help from HA community (on a different but related problem: looks like z-wave is not a priority within HA). I hope you can tell me if this is a Inovelli problem (did I pair it right?), or this is a HA problem, so I can start the debugging process. Also, I could NOT unpair it: the unpairing process always end up with LED bar being red.
I purchased these Inovelli dimmer switch from amazon.ca new.
any help is very much appreciated,
log below:
Blockquote
2020-08-17 21:22:00.117 Detail, Queuing (Controller) Add Device
2020-08-17 21:22:00.117 Info, WriteNextMsg Controller nothing to do
2020-08-17 21:22:02.729 Detail, Received: 0x01, 0x07, 0x00, 0x4b, 0x92, 0x02, 0x00, 0x00, 0x23
2020-08-17 21:22:02.729 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-08-17 21:22:02.729 Info, REMOVE_NODE_STATUS_NODE_FOUND
2020-08-17 21:22:02.729 Detail, Notification: ControllerCommand - InProgress
2020-08-17 21:22:03.138 Detail, Received: 0x01, 0x1a, 0x00, 0x4b, 0x92, 0x03, 0x00, 0x13, 0x04, 0x11, 0x01, 0x5e, 0x26, 0x70, 0x85, 0x59, 0x55, 0x86, 0x72, 0x5a, 0x73, 0x98, 0x9f, 0x6c, 0x75, 0x22, 0x7a, 0x22
2020-08-17 21:22:03.138 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-08-17 21:22:03.138 Info, REMOVE_NODE_STATUS_REMOVING_SLAVE
2020-08-17 21:22:03.139 Warning, Remove Node Failed - NodeID 0 Returned
2020-08-17 21:22:03.139 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.139 Info, Add Device
2020-08-17 21:22:03.139 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x93, 0xe2
2020-08-17 21:22:03.139 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.139 Info, contrlr, Sending (Command) message (Callback ID=0x93, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x93, 0xe2
2020-08-17 21:22:03.140 Detail, Unsolicited message received while waiting for ACK.
2020-08-17 21:22:03.141 Detail, contrlr, Received: 0x01, 0x1a, 0x00, 0x4b, 0x92, 0x06, 0x00, 0x13, 0x04, 0x11, 0x01, 0x5e, 0x26, 0x70, 0x85, 0x59, 0x55, 0x86, 0x72, 0x5a, 0x73, 0x98, 0x9f, 0x6c, 0x75, 0x22, 0x7a, 0x27
2020-08-17 21:22:03.141 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-08-17 21:22:03.141 Info, REMOVE_NODE_STATUS_DONE
2020-08-17 21:22:03.141 Detail, Notification: ControllerCommand - Completed
2020-08-17 21:22:03.142 Detail, contrlr, CAN received…triggering resend
2020-08-17 21:22:03.142 Info, contrlr, Sending (Command) message (Attempt 2, Callback ID=0x94, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x94, 0xe5
2020-08-17 21:22:03.146 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x94, 0x01, 0x00, 0x00, 0x27
2020-08-17 21:22:03.146 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-08-17 21:22:03.146 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-08-17 21:22:03.146 Detail, Node001, Expected callbackId was received
2020-08-17 21:22:03.146 Detail, Node001, Expected reply was received
2020-08-17 21:22:03.146 Detail, Node001, Message transaction complete
2020-08-17 21:22:03.147 Detail, contrlr, Removing current message
2020-08-17 21:22:03.147 Detail, Notification: ControllerCommand - Waiting
2020-08-17 21:22:03.147 Info, Remove Device
2020-08-17 21:22:03.147 Detail, contrlr, Queuing (Command) ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x95, 0xa5
2020-08-17 21:22:03.147 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.148 Detail,
2020-08-17 21:22:03.148 Info, contrlr, Sending (Command) message (Callback ID=0x95, Expected Reply=0x4b) - ControllerCommand_RemoveDevice: 0x01, 0x05, 0x00, 0x4b, 0x81, 0x95, 0xa5
2020-08-17 21:22:03.154 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4b, 0x95, 0x07, 0x00, 0x00, 0x21
2020-08-17 21:22:03.154 Info, FUNC_ID_ZW_REMOVE_NODE_FROM_NETWORK:
2020-08-17 21:22:03.154 Warning, WARNING: REMOVE_NODE_STATUS_FAILED
2020-08-17 21:22:03.154 Detail, Node007, Expected callbackId was received
2020-08-17 21:22:03.154 Detail, Node007, Expected reply was received
2020-08-17 21:22:03.154 Detail, Node007, Message transaction complete
2020-08-17 21:22:03.155 Detail, contrlr, Removing current message
2020-08-17 21:22:03.155 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.155 Info, Requesting Neighbor Update for node 1
2020-08-17 21:22:03.155 Detail, Node001, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x96, 0x25
2020-08-17 21:22:03.155 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.155 Info, Node001, Sending (Command) message (Callback ID=0x96, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x96, 0x25
2020-08-17 21:22:03.158 Detail, Node001, Received: 0x01, 0x05, 0x00, 0x48, 0x96, 0x23, 0x07
2020-08-17 21:22:03.158 Warning, Node001, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-08-17 21:22:03.158 Detail, Node035, Expected callbackId was received
2020-08-17 21:22:03.158 Detail, Node035, Expected reply was received
2020-08-17 21:22:03.158 Detail, Node035, Message transaction complete
2020-08-17 21:22:03.158 Detail, Node001, Removing current message
2020-08-17 21:22:03.159 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.159 Info, Requesting Neighbor Update for node 6
2020-08-17 21:22:03.159 Detail, Node006, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=6): 0x01, 0x05, 0x00, 0x48, 0x06, 0x97, 0x23
2020-08-17 21:22:03.159 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.159 Info, Node006, Sending (Command) message (Callback ID=0x97, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=6): 0x01, 0x05, 0x00, 0x48, 0x06, 0x97, 0x23
2020-08-17 21:22:03.165 Detail, Node006, Received: 0x01, 0x05, 0x00, 0x48, 0x97, 0x23, 0x06
2020-08-17 21:22:03.165 Warning, Node006, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-08-17 21:22:03.165 Detail, Node035, Expected callbackId was received
2020-08-17 21:22:03.165 Detail, Node035, Expected reply was received
2020-08-17 21:22:03.165 Detail, Node035, Message transaction complete
2020-08-17 21:22:03.165 Detail, Node006, Removing current message
2020-08-17 21:22:03.166 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.166 Info, Requesting Neighbor Update for node 7
2020-08-17 21:22:03.166 Detail, Node007, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=7): 0x01, 0x05, 0x00, 0x48, 0x07, 0x98, 0x2d
2020-08-17 21:22:03.166 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.166 Info, Node007, Sending (Command) message (Callback ID=0x98, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=7): 0x01, 0x05, 0x00, 0x48, 0x07, 0x98, 0x2d
2020-08-17 21:22:03.169 Detail, Node007, Received: 0x01, 0x05, 0x00, 0x48, 0x98, 0x23, 0x09
2020-08-17 21:22:03.169 Warning, Node007, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-08-17 21:22:03.169 Detail, Node035, Expected callbackId was received
2020-08-17 21:22:03.169 Detail, Node035, Expected reply was received
2020-08-17 21:22:03.170 Detail, Node035, Message transaction complete
2020-08-17 21:22:03.170 Detail, Node007, Removing current message
2020-08-17 21:22:03.170 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.170 Info, Requesting Neighbor Update for node 8
2020-08-17 21:22:03.170 Detail, Node008, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=8): 0x01, 0x05, 0x00, 0x48, 0x08, 0x99, 0x23
2020-08-17 21:22:03.170 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.170 Info, Node008, Sending (Command) message (Callback ID=0x99, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=8): 0x01, 0x05, 0x00, 0x48, 0x08, 0x99, 0x23
2020-08-17 21:22:03.173 Detail, Node008, Received: 0x01, 0x05, 0x00, 0x48, 0x99, 0x23, 0x08
2020-08-17 21:22:03.173 Warning, Node008, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-08-17 21:22:03.173 Detail, Node035, Expected callbackId was received
2020-08-17 21:22:03.173 Detail, Node035, Expected reply was received
2020-08-17 21:22:03.173 Detail, Node035, Message transaction complete
2020-08-17 21:22:03.173 Detail, Node008, Removing current message
2020-08-17 21:22:03.174 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.174 Info, Requesting Neighbor Update for node 10
2020-08-17 21:22:03.174 Detail, Node010, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=10): 0x01, 0x05, 0x00, 0x48, 0x0a, 0x9a, 0x22
2020-08-17 21:22:03.174 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.174 Info, Node010, Sending (Command) message (Callback ID=0x9a, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=10): 0x01, 0x05, 0x00, 0x48, 0x0a, 0x9a, 0x22
2020-08-17 21:22:03.177 Detail, Node010, Received: 0x01, 0x05, 0x00, 0x48, 0x9a, 0x23, 0x0b
2020-08-17 21:22:03.177 Warning, Node010, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-08-17 21:22:03.177 Detail, Node035, Expected callbackId was received
2020-08-17 21:22:03.177 Detail, Node035, Expected reply was received
2020-08-17 21:22:03.177 Detail, Node035, Message transaction complete
2020-08-17 21:22:03.178 Detail,
2020-08-17 21:22:03.178 Detail, Node010, Removing current message
2020-08-17 21:22:03.178 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.178 Info, Requesting Neighbor Update for node 11
2020-08-17 21:22:03.178 Detail, Node011, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=11): 0x01, 0x05, 0x00, 0x48, 0x0b, 0x9b, 0x22
2020-08-17 21:22:03.178 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.178 Info, Node011, Sending (Command) message (Callback ID=0x9b, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=11): 0x01, 0x05, 0x00, 0x48, 0x0b, 0x9b, 0x22
2020-08-17 21:22:03.181 Detail, Node011, Received: 0x01, 0x05, 0x00, 0x48, 0x9b, 0x23, 0x0a
2020-08-17 21:22:03.181 Warning, Node011, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-08-17 21:22:03.181 Detail, Node035, Expected callbackId was received
2020-08-17 21:22:03.181 Detail, Node035, Expected reply was received
2020-08-17 21:22:03.181 Detail, Node035, Message transaction complete
2020-08-17 21:22:03.181 Detail, Node011, Removing current message
2020-08-17 21:22:03.182 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.182 Info, Requesting Neighbor Update for node 14
2020-08-17 21:22:03.182 Detail, Node014, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=14): 0x01, 0x05, 0x00, 0x48, 0x0e, 0x9c, 0x20
2020-08-17 21:22:03.182 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.183 Detail,
2020-08-17 21:22:03.183 Info, Node014, Sending (Command) message (Callback ID=0x9c, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=14): 0x01, 0x05, 0x00, 0x48, 0x0e, 0x9c, 0x20
2020-08-17 21:22:03.185 Detail, Node014, Received: 0x01, 0x05, 0x00, 0x48, 0x9c, 0x23, 0x0d
2020-08-17 21:22:03.185 Warning, Node014, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-08-17 21:22:03.185 Detail, Node035, Expected callbackId was received
2020-08-17 21:22:03.185 Detail, Node035, Expected reply was received
2020-08-17 21:22:03.185 Detail, Node035, Message transaction complete
2020-08-17 21:22:03.185 Detail, Node014, Removing current message
2020-08-17 21:22:03.186 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.186 Info, Add Device
2020-08-17 21:22:03.186 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x9d, 0xec
2020-08-17 21:22:03.186 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.186 Info, contrlr, Sending (Command) message (Callback ID=0x9d, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x9d, 0xec
2020-08-17 21:22:03.190 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x9d, 0x07, 0x00, 0x00, 0x28
2020-08-17 21:22:03.190 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-08-17 21:22:03.190 Info, contrlr, ADD_NODE_STATUS_FAILED
2020-08-17 21:22:03.190 Detail, contrlr, Removing current message
2020-08-17 21:22:03.190 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-08-17 21:22:03.190 Detail, Notification: ControllerCommand - Failed
2020-08-17 21:22:03.191 Detail,
2020-08-17 21:22:03.191 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-08-17 21:22:03.247 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x9d, 0x06, 0x00, 0x00, 0x29
2020-08-17 21:22:03.248 Detail,
2020-08-17 21:22:03.248 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-08-17 21:22:03.248 Detail, Node006, Expected reply was received
2020-08-17 21:22:03.248 Detail, Node006, Message transaction complete
2020-08-17 21:22:03.248 Detail, contrlr, Removing current message
2020-08-17 21:22:03.248 Detail, Notification: ControllerCommand - Completed
2020-08-17 21:22:03.249 Info, Add Device
2020-08-17 21:22:03.249 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x9e, 0xef
2020-08-17 21:22:03.249 Detail, Notification: ControllerCommand - Starting
2020-08-17 21:22:03.250 Detail,
2020-08-17 21:22:03.250 Info, contrlr, Sending (Command) message (Callback ID=0x9e, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x9e, 0xef
2020-08-17 21:22:03.253 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x9e, 0x01, 0x00, 0x00, 0x2d
2020-08-17 21:22:03.254 Detail,
2020-08-17 21:22:03.254 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-08-17 21:22:03.254 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-08-17 21:22:03.254 Detail, Node001, Expected callbackId was received
2020-08-17 21:22:03.254 Detail, Node001, Expected reply was received
2020-08-17 21:22:03.254 Detail, Node001, Message transaction complete
2020-08-17 21:22:03.254 Detail, contrlr, Removing current message
2020-08-17 21:22:03.254 Detail, Notification: ControllerCommand - Waiting
2020-08-17 21:22:03.255 Info, WriteNextMsg Controller nothing to do
Blockquote
I’m not an HA person, but I would recommend doing a factory rest by pressing the config button down for 20 + seconds until the LED bar goes red.
