My Biggest problem with smart switches is the space they take up in wall box (especially multi-gang boxes) (inovelli switches are smaller than most smart switches but still quite a bit bigger than non automated switches ) Suggestion:
Provide side pass-through connections and a connector (sized to spread switches standard distance in wall box) for the line, neutral and ground to reduce the number of wires in the box. This way in the wall box you would only need to connect theses to one of the switches reducing the number of pig tails or space taken by using other wires to chain devices together.
Thanks
Bill
