image not found img not found
Inovelli Community
Posting format in this category and sub category
When you post a question or need help please follow this format:
Topic needs to include Device/Series and what Hub you are using.
EG: Dimmer | LZW31 or LZW31-SN | Red | Hubitat - Turns off with no interaction
In the body as much info as possible such as pictures of the wiring at the gang box and what driver you are using, with Hubitat you need to specify the stock drivers or the Hubitat versions.
This will help more then you think ! Please search the forum before posting to prevent duplicates.
Thanks !
